查看: 5720|回复: 0
ISO国际标准化组织ISO-2024国际标准【中文版翻译+PDF原版】全文获取
发表于 2025-3-11 19:40 | 显示全部楼层 |阅读模式
ISO 22928-1:2024
Rare earth - Analysis by wavelength dispersive x-ray fluorescence spectrometry (WD-XRFS) - Part 1: Determination of composition of rare earth magnet scrap using standardless XRF commercial packages
STANDARD by International Organization for Standardization, 03/01/2024.
LANGUAGES: English+Chinese 英文+翻译
ISO 7448:2024
Machinery for forestry - Machine-fed woody biomass reduction chippers, grinders, and shredders - Vocabulary
ISO 24221:2024
Railway applications - Braking system - General requirements
ISO 5735-1:2024
Railway infrastructure - Non-destructive testing on rails in track - Part 1: Requirements for ultrasonic testing and evaluation principles
ISO 9924-3:2024
Rubber and rubber products - Determination of the composition of vulcanizates and uncured compounds by thermogravimetry - Part 3: Hydrocarbon rubbers, halogenated rubbers and polysiloxane rubbers
HISTORICAL EDITIONS: ISO 9924-3:2009
ISO 16132:2024
Ductile iron pipes and fittings - Seal coats for cement mortar linings
HISTORICAL EDITIONS: ISO 16132:2016, ISO 16132:2004
ISO 7383-1:2024
Fine bubble technology - Evaluation method for determining gas content in fine bubble dispersions in water - Part 1: Oxygen content
ISO 12185:2024
Crude petroleum, petroleum products and related products - Determination of density - Laboratory density meter with an oscillating U-tube sensor
HISTORICAL EDITIONS: ISO 12185:1996
ISO 16000-9:2024
Indoor air - Part 9: Determination of the emission of volatile organic compounds from samples of building products and furnishing - Emission test chamber method
HISTORICAL EDITIONS: ISO 16000-9:2006
ISO 22578-2:2024
Graphical symbols - Safety colours and safety signs - Part 2: Measurement of photopic luminance of phosphorescent components used in a natural disaster safety way guidance system
ISO 8060:2024
Composites and reinforcements fibres - Carbon fibre reinforced plastics (CFRPs) and metal assemblies - Characterization of durability of adhesive interfaces by wedge rupture test
ISO 32312-11:2024
Aircraft ground support equipment - Specific requirements - Part 11: Container/Pallet dollies and loose load trailers
ISO 14953:2024
Space systems - Structural design - Determination of loading levels for static qualification testing of launch vehicles
HISTORICAL EDITIONS: ISO 14953:2000
ISO 45004:2024
Occupational health and safety management - Guidelines on performance evaluation
ISO 18128:2024
Information and documentation - Records risks - Risk assessment for records management
HISTORICAL EDITIONS: ISO/TR 18128:2014
ISO 3164:2013/Amd1:2024
- Amendment 1: Earth-moving machinery - Laboratory evaluations of protective structures - Specifications for deflection-limiting volume - Amendment 1
AMENDMENT by International Organization for Standardization, 03/01/2024.
ISO 4917-4:2024
Design of nuclear power plants against seismic events - Part 4: Components
ISO 13100:2024
Methods for zeta potential determination - Streaming potential and streaming current methods for porous materials
ISO 18562-1:2024
Biocompatibility evaluation of breathing gas pathways in healthcare applications - Part 1: Evaluation and testing within a risk management process
HISTORICAL EDITIONS: ISO 18562-1:2017
ISO 13702:2024
Oil and gas industries - Control and mitigation of fires and explosions on offshore production installations - Requirements and guidelines
HISTORICAL EDITIONS: ISO 13702:2015, ISO 13702:1999
ISO 17294-1:2024
Water quality - Application of inductively coupled plasma mass spectrometry (ICP-MS) - Part 1: General requirements
HISTORICAL EDITIONS: ISO 17294-1:2004
ISO 16454:2024
Space systems - Structural design - Stress analysis requirements
HISTORICAL EDITIONS: ISO 16454:2007
ISO 4126-10:2024
Safety devices for protection against excessive pressure - Part 10: Sizing of safety valves and bursting discs for gas/liquid two-phase flow
HISTORICAL EDITIONS: ISO 4126-10:2010
ISO 20688-2:2024
Biotechnology - Nucleic acid synthesis - Part 2: Requirements for the production and quality control of synthesized gene fragments, genes, and genomes
ISO 14289-2:2024
Document management applications - Electronic document file format enhancement for accessibility - Part 2: Use of ISO 32000-2 (PDF/UA-2)
ISO 3834-6:2024
Quality requirements for fusion welding of metallic materials - Part 6: Guidelines on implementing the ISO 3834 series
HISTORICAL EDITIONS: ISO/TR 3834-6:2007
ISO 18692-5:2024
Fibre ropes for offshore stationkeeping - Part 5: Aramid
HISTORICAL EDITIONS: ISO/TS 17920:2015
ISO 22662:2024
Milk and milk products - Determination of lactose content by high-performance liquid chromatography (reference method)
HISTORICAL EDITIONS: ISO 22662:2007
ISO 2773:2024
Test conditions for pillar type vertical drilling machines - Testing of accuracy
HISTORICAL EDITIONS: ISO 27730:2012, ISO 2773-2:1973, ISO 2773-1:1973
ISO 22435:2024
Gas cylinders - Cylinder valves with integrated pressure regulators - Specification and type testing
HISTORICAL EDITIONS: ISO 22435:2007
ISO 18562-4:2024
Biocompatibility evaluation of breathing gas pathways in healthcare applications - Part 4: Tests for leachables in condensate
HISTORICAL EDITIONS: ISO 18562-4:2017
ISO 2469:2024
Paper, board and pulps - Measurement of diffuse radiance factor (diffuse reflectance factor)
HISTORICAL EDITIONS: ISO 2469:2014, ISO 2469:2007, ISO 2469:1994
ISO 8233:2024
Thermoplastics valves - Torque - Test method
HISTORICAL EDITIONS: ISO 18233:2006, ISO 8233:1988
ISO 21538:2024
Blanks for superabrasive cutting-off wheels - Mounting and fixing bores - Building construction and civil engineering
HISTORICAL EDITIONS: ISO 21538:2016, ISO 21538:2004
ISO 6273:2024
Assistive products - Accessibility guidelines and requirements to survey the needs of persons with sensory disabilities for assistive products and services
ISO 3384-1:2024
Rubber, vulcanized or thermoplastic - Determination of stress relaxation in compression - Part 1: Testing at constant temperature
HISTORICAL EDITIONS: ISO 3384-1:2019, ISO 3384-1:2011, ISO 3384:2005, ISO 3384:1999
ISO 3384-1:2024
ISO 12808:2024
Hardware for furniture - Strength and durability of extension elements and their components
ISO 14289-2:2024
ISO 14953:2024
ISO 21622-3:2024
Irrigation techniques - Remote monitoring and control for irrigation - Part 3: Interoperability
ISO 34257:2024
Adhesives - Wood adhesives - Determination of tensile strength of lap joints at elevated temperature (WATT 91)
ISO 24163-1:2024
Clamp-in tyre valves for tyre pressure monitoring systems - Part 1: Definition, types, dimensions and valve interface
ISO 16620-4:2024
Plastics - Biobased content - Part 4: Determination of biobased mass content
HISTORICAL EDITIONS: ISO 16620-4:2016
ISO 18692-5:2024
ISO 34256:2024
Adhesives for non-structural wood applications - Test method and requirements for resistance to static load
ISO 2469:2024
ISO 687:2024
Coke - Determination of moisture in the general analysis test sample
HISTORICAL EDITIONS: ISO 687:2010, ISO 687:2004
ISO 19234:2024
Hydrometry - Low cost baffles to aid fish passage on triangular profile gauging weirs
HISTORICAL EDITIONS: ISO/TR 19234:2016
ISO 16311-2:2024
Maintenance and repair of concrete structures - Part 2: Assessment of existing concrete structures
HISTORICAL EDITIONS: ISO 16311-2:2014
ISO 16739-1:2024
Industry Foundation Classes (IFC) for data sharing in the construction and facility management industries - Part 1: Data schema
HISTORICAL EDITIONS: ISO 16739-1:2018, ISO 16739:2013, ISO/PAS 16739:2005
ISO 11898-2:2024
Road vehicles - Controller area network (CAN) - Part 2: High-speed physical medium attachment (PMA) sublayer
HISTORICAL EDITIONS: ISO 11898-2:2016, ISO 11898-2:2003
ISO 5832-11:2024
Implants for surgery - Metallic materials - Part 11: Wrought titanium 6-aluminium 7-niobium alloy
HISTORICAL EDITIONS: ISO 5832-11:2014, ISO 5832-11:1994
ISO 105-B04:2024
Textiles - Tests for colour fastness - Part B04: Colour fastness to artificial weathering: Xenon arc fading lamp test
HISTORICAL EDITIONS: ISO 105-B04:1994
ISO 16400-3:2024
Automation systems and integration - Equipment behaviour catalogues for virtual production system - Part 3: Requirements and recommendations for construction of an equipment instance model
ISO 28000:2022/Amd1:2024
- Amendment 1: Security and resilience - Security management systems - Requirements - Amendment 1: Climate action changes
AMENDMENT by International Organization for Standardization, 02/01/2024.
ISO 10302-1:2024
Acoustics - Measurement of airborne noise emitted and structure-borne vibration induced by small air-moving devices - Part 1: Airborne noise measurement
STANDARD by International Organization for Standardization, 02/01/2024.
HISTORICAL EDITIONS: ISO 10302-1:2011, ISO 10302:1996
ISO 18335:2024
Petroleum products and related products - Determination of kinematic viscosity by calculation from the measured dynamic viscosity and density – Method by constant pressure viscometer
ISO 14298:2021/Amd1:2024
- Amendment 1: Graphic technology - Management of security printing processes - Amendment 1: Climate action changes
ISO 19443:2018/Amd1:2024
- Amendment 1: Quality management systems - Specific requirements for the application of ISO 9001:2015 by organizations in the supply chain of the nuclear energy sector supplying products and services important to nuclear safety (ITNS) - Amendment 1: Climate action changes
ISO 24512:2024
Activities relating to drinking water and wastewater services - Guidelines for the management of drinking water utilities and for the assessment of drinking water services
HISTORICAL EDITIONS: ISO 24512:2007
ISO 19847:2024
Ships and marine technology - Shipboard data servers for sharing field data at sea
HISTORICAL EDITIONS: ISO 19847:2018
ISO 16422-5:2024
Pipes and joints made of oriented unplasticized poly(vinyl chloride) (PVC-O) for the conveyance of water under pressure - Part 5: Fitness for purpose of the system
HISTORICAL EDITIONS: ISO 16422:2014, ISO 16422:2006
ISO 19848:2024
Ships and marine technology - Standard data for shipboard machinery and equipment
HISTORICAL EDITIONS: ISO 19848:2018
ISO 21101:2014/Amd1:2024
- Amendment 1: Adventure tourism - Safety management systems - Requirements - Amendment 1: Climate action changes
ISO 4437-5:2024
Plastics piping systems for the supply of gaseous fuels - Polyethylene (PE) - Part 5: Fitness for purpose of the system
HISTORICAL EDITIONS: ISO 4437-5:2014, ISO 4437:2007, ISO 10933:1997, ISO 4437:1997
ISO 7158:2024
Meat and meat products - Determination of nitrite and nitrate content - Ion chromatography method
HISTORICAL EDITIONS: ISO 37158:2019
ISO 21549-7:2024
Health informatics - Patient healthcard data - Part 7: Medication data
HISTORICAL EDITIONS: ISO 21549-7:2016, ISO 21549-7:2007
ISO 4437-3:2024
Plastics piping systems for the supply of gaseous fuels - Polyethylene (PE) - Part 3: Fittings
HISTORICAL EDITIONS: ISO 4437-3:2014, ISO 4437:2007, ISO 8085-3:2001, ISO 8085-1:2001, ISO 8085-2:2001, ISO 4437:1997
ISO 3549:2024
Zinc dust pigments for paints - Specifications and test methods
HISTORICAL EDITIONS: ISO 3549:1995
ISO 10303-2:2024
Industrial automation systems and integration - Product data representation and exchange - Part 2: Vocabulary
ISO 37301:2021/Amd1:2024
- Amendment 1: Compliance management systems - Requirements with guidance for use - Amendment 1: Climate action changes
ISO 34504:2024
Road vehicles - Test scenarios for automated driving systems - Scenario categorization
ISO 16032:2024
Acoustics - Measurement of sound pressure level from service equipment or activities in buildings - Engineering method
HISTORICAL EDITIONS: ISO 16032:2004
ISO 17546:2024
Space systems - Lithium ion battery for space vehicles - Design and verification requirements
HISTORICAL EDITIONS: ISO 17546:2016
ISO 41011:2024
Facility management - Vocabulary
HISTORICAL EDITIONS: ISO 41011:2017
ISO 27852:2024
Space systems - Estimation of orbit lifetime
HISTORICAL EDITIONS: ISO 27852:2016, ISO 27852:2011
ISO 4437-2:2024
Plastics piping systems for the supply of gaseous fuels - Polyethylene (PE) - Part 2: Pipes
HISTORICAL EDITIONS: ISO 4437-2:2014, ISO 4437:2007, ISO 4437:1997
ISO 12604-2:2024
Aircraft ground handling - Checked baggage - Part 2: Handling requirements and guidelines
ISO 4437-1:2024
Plastics piping systems for the supply of gaseous fuels - Polyethylene (PE) - Part 1: General
HISTORICAL EDITIONS: ISO 4437-1:2014, ISO 4437:2007, ISO 4437:1997
ISO 7935:2024
Stationary source emissions - Determination of the mass concentration of sulfur dioxide in flue gases - Performance characteristics of automated measuring systems
HISTORICAL EDITIONS: ISO 7935:1992
ISO 12460-2:2024
Wood-based panels - Determination of formaldehyde release - Part 2: Small-scale chamber method
HISTORICAL EDITIONS: ISO 12460-2:2018
ISO 26900:2024
Space data and information transfer systems - Orbit data messages
HISTORICAL EDITIONS: ISO 26900:2012, ISO 22644:2006
ISO 44001:2017/Amd1:2024
- Amendment 1: Collaborative business relationship management systems - Requirements and framework - Amendment 1: Climate action changes
ISO 23795-2:2024
Intelligent transport systems - Extracting trip data using nomadic and mobile devices for estimating CO2 emissions - Part 2: Information provision for eco-friendly driving behaviour
ISO 24511:2024
Activities relating to drinking water and wastewater services - Guidelines for the management of wastewater utilities and for the assessment of wastewater services
HISTORICAL EDITIONS: ISO 24511:2007
ISO 24596:2024
Drinking water, wastewater and stormwater systems and services - Guidelines for the planning and implementation of infrastructure hardening for water and wastewater systems
ISO 6350:2024
Lignins - Determination of dry matter content - Oven-drying and freeze-drying methods
ISO 19847:2024
ISO 12604-2:2024
ISO 22166-201:2024
Robotics - Modularity for service robots - Part 201: Common information model for modules
ISO 19694-7:2024
Stationary source emissions - Determination of greenhouse gas emissions in energy-intensive industries - Part 7: Semiconductor and display industries
ISO 10302-1:2024
ISO 105-C12:2024
Textiles - Tests for colour fastness - Part C12: Colour fastness to industrial laundering
HISTORICAL EDITIONS: ISO 105-C12:2004
ISO 23217:2024
Injection systems for self-administration by paediatric patients - Requirements and guidelines for design
ISO 4437-2:2024
ISO 5553:2024
Meat and meat products - Detection of condensed phosphates
HISTORICAL EDITIONS: ISO 5553:1980
ISO 41001:2018/Amd1:2024
- Amendment 1: Facility management - Management systems - Requirements with guidance for use - Amendment 1: Climate action changes
ISO 603-9:2024
Bonded abrasive products - Dimensions - Part 9: Grinding wheels for high-pressure grinding
HISTORICAL EDITIONS: ISO 603-9/Cor1:1999, ISO 603-9:1999
ISO 3549:2024
ISO 24512:2024
ISO 18183-3:2024
Geometrical product specifications (GPS) - Partition - Part 3: Methods used for specification and verification
ISO 18183-2:2024
Geometrical product specifications (GPS) - Partition - Part 2: Nominal model
ISO 15589-2:2024
Oil and gas industries including lower carbon energy - Cathodic protection of pipeline transportation systems - Part 2: Offshore pipelines
HISTORICAL EDITIONS: ISO 15589-2:2012, ISO 15589-2:2004
ISO 50001:2018/Amd1:2024
- Amendment 1: Energy management systems - Requirements with guidance for use - Amendment 1: Climate action changes
ISO 7921:2024
Ophthalmic optics and instruments - Near reading charts
ISO 13611:2024
Interpreting services - Community interpreting - Requirements and recommendations
HISTORICAL EDITIONS: ISO 13611:2014
ISO 10109:2024
Optics and photonics - Guidance for the selection of environmental tests
HISTORICAL EDITIONS: ISO 10109:2015, ISO 10109:2014, ISO 10109-1:2005, ISO 10109-6:2005, ISO 10109-8:2005, ISO 10109-12:2004, ISO 10109-11:2001, ISO 10109-7:2001, ISO 10109-1:1994, ISO 10109-6:1994, ISO 10109-8:1994
ISO 18788:2015/Amd1:2024
- Amendment 1: Management system for private security operations - Requirements with guidance for use - Amendment 1: Climate action changes
ISO 9001:2015/Amd1:2024
- Amendment 1: Quality management systems - Requirements - Amendment 1: Climate action changes
ISO 23795-2:2024
ISO 813-2:2024
Rubber, vulcanized or thermoplastic - Determination of adhesion to a rigid substrate - Part 2: Adhesion of a soft thermoplastic elastomer layer
HISTORICAL EDITIONS: ISO 10813-2:2019
ISO 29001:2020/Amd1:2024
- Amendment 1: Petroleum, petrochemical and natural gas industries - Sector-specific quality management systems - Requirements for product and service supply organizations - Amendment 1: Climate action changes
ISO 34101-1:2019/Amd1:2024
- Amendment 1: Sustainable and traceable cocoa - Part 1: Requirements for cocoa sustainability management systems - Amendment 1: Climate action changes
ISO 10303-2:2024
ISO 18335:2024
ISO 9211-2:2024
Optics and photonics - Optical coatings - Part 2: Optical properties
HISTORICAL EDITIONS: ISO 9211-2:2010, ISO 9211-2:1994
ISO 4437-1:2024
ISO 7158:2024
ISO 13061-13:2024
Physical and mechanical properties of wood - Test methods for small clear wood specimens - Part 13: Determination of radial and tangential shrinkage
HISTORICAL EDITIONS: ISO 13061-13:2016, ISO 4469:1981
ISO 9692-2:2024
Welding and allied processes - Joint preparation - Part 2: Submerged arc welding of steels
HISTORICAL EDITIONS: ISO 9692-2:1998
ISO 9319:2024
Traditional Chinese medicine - Poria cocos sclerotium
ISO 22185-2:2024
Diagnosing moisture damage in buildings and implementing countermeasures - Part 2: Assessment of conditions
ISO 4437-5:2024
ISO 7935:2024
ISO 16422-2:2024
Pipes and joints made of oriented unplasticized poly(vinyl chloride) (PVC-O) for the conveyance of water under pressure - Part 2: Pipes
ISO 16400-2:2024
Automation systems and integration - Equipment behaviour catalogues for virtual production systems - Part 2: Formal description of a catalogue template
ISO 12460-2:2024
ISO 16422-5:2024
ISO 27852:2024
ISO 24511:2024
ISO 39001:2012/Amd1:2024
- Amendment 1: Road traffic safety (RTS) management systems - Requirements with guidance for use - Amendment 1: Climate action changes
ISO 6142-2:2024
Gas analysis - Preparation of calibration gas mixtures - Part 2: Gravimetric method for Class II mixtures
ISO 16422-2:2024
ISO 24511:2024
ISO 10364:2024
Structural adhesives - Determination of the pot life (working life) of multi-component adhesives
HISTORICAL EDITIONS: ISO 10364:2015, ISO 10364:2007, ISO 10364:1993
ISO 9692-2:2024
ISO 17546:2024
ISO 22000:2018/Amd1:2024
- Amendment 1: Food safety management systems - Requirements for any organization in the food chain - Amendment 1: Climate action changes
ISO 5060:2024
Translation services - Evaluation of translation output - General guidance
ISO 18183-3:2024
ISO 9211-1:2024
Optics and photonics - Optical coatings - Part 1: Vocabulary
HISTORICAL EDITIONS: ISO 9211-1:2018, ISO 9211-1:2010, ISO 9211-1:1994
ISO 6142-2:2024
ISO 23217:2024
ISO 23745:2024
Ships and marine technology - General specification for shipborne meteorological instruments
ISO 22185-2:2024
ISO 35001:2019/Amd1:2024
- Amendment 1: Biorisk management for laboratories and other related organisations - Amendment 1: Climate action changes
ISO 24596:2024
ISO 19694-7:2024
ISO 24544:2024
Rare earth - Recyclable Neodymium iron boron (NdFeB) resources - Classification, general requirements and acceptance conditions
ISO 19847:2024
ISO 10109:2024
ISO 11855-7:2019/Amd1:2024
- Amendment 1: Building environment design - Design, dimensioning, installation and control of embedded radiant heating and cooling systems - Part 7: Input parameters for the energy calculation - Amendment 1
AMENDMENT by International Organization for Standardization, 01/01/2024.
ISO 11816-2:2024
Milk and milk products - Determination of alkaline phosphatase activity - Part 2: Fluorimetric method for cheese
STANDARD by International Organization for Standardization, 01/01/2024.
HISTORICAL EDITIONS: ISO 11816-2:2016, ISO 11816-2:2003
ISO 5640:2024
Industrial valves - Mounting kits for part-turn valve actuator attachment
ISO 9455-17:2024
Soft soldering fluxes - Test methods - Part 17: Surface insulation resistance comb test and electrochemical migration test of flux residues
HISTORICAL EDITIONS: ISO 9455-17:2002
ISO 14520-5:2024
Gaseous fire-extinguishing systems - Physical properties and system design - Part 5: FK-5-1-12 extinguishant
HISTORICAL EDITIONS: ISO 14520-5:2019, ISO 14520-5:2016, ISO 14520-5:2006, ISO/DIS 14520-5:1998
ISO 3882:2024
Metallic and other inorganic coatings - Review of methods of measurement of thickness
HISTORICAL EDITIONS: ISO 3882:2003
ISO 6017:2024
Small craft - Automatic watertight ventilation shutdown system
ISO 17651-1:2024
Simultaneous interpreting - Interpreters’ working environment - Part 1: Requirements and recommendations for permanent booths
HISTORICAL EDITIONS: ISO 2603:2016, ISO 2603:1998
ISO 24183:2024
Technical communication - Vocabulary
ISO 23337:2024
Rubber, vulcanized or thermoplastic - Determination of abrasion resistance using the Improved Lambourn test machine
HISTORICAL EDITIONS: ISO 23337:2016, ISO 23337:2007
ISO 7240-29:2024
Fire detection and alarm systems - Part 29: Video fire detectors
HISTORICAL EDITIONS: ISO/TS 7240-29:2017
ISO 16684-4:2024
Graphic technology - Extensible metadata platform (XMP) specification - Part 4: Use of XMP for semantic units
ISO 3262-11:2024
Extenders - Specifications and methods of test - Part 11: Natural talc, in lamellar form, containing carbonates
HISTORICAL EDITIONS: ISO 3262-11:2000
ISO 7431-1:2024
Thiourea for industrial use - Part 1: Test methods
ISO 19152-1:2024
Geographic information - Land Administration Domain Model (LADM) - Part 1: Generic conceptual model
ISO 16484-1:2024
Building automation and control systems (BACS) - Part 1: Project specification and implementation
HISTORICAL EDITIONS: ISO 16484-1:2010
ISO 3262-10:2024
Extenders - Specifications and methods of test - Part 10: Natural talc/chlorite in lamellar form
HISTORICAL EDITIONS: ISO 3262-10:2000
ISO 19901-3:2024
Oil and gas industries including lower carbon energy - Specific requirements for offshore structures - Part 3: Topsides structure
HISTORICAL EDITIONS: ISO 19901-3:2014, ISO 19901-3:2010
ISO 11816-1:2024
Milk and milk products - Determination of alkaline phosphatase activity - Part 1: Fluorimetric method for milk and milk-based drinks
HISTORICAL EDITIONS: ISO 11816-1:2013, ISO 11816-1:2006, ISO 11816-1:1997
ISO 4678:2024
Ships and marine technology - Noise measurement method for HVAC system in accommodation spaces
ISO 9:1995/Amd1:2024
- Amendment 1: Information and documentation - Transliteration of Cyrillic characters into Latin characters - Slavic and non-Slavic languages - Amendment 1
ISO 15611:2024
Specification and qualification of welding procedures for metallic materials - Qualification based on previous welding experience
HISTORICAL EDITIONS: ISO 15611:2003
ISO 8025:2024
Ergonomics of the thermal environment - Management of working conditions in hot environments
ISO 10303-1:2024
Industrial automation systems and integration - Product data representation and exchange - Part 1: Overview and fundamental principles
HISTORICAL EDITIONS: ISO 10303-1:2021, ISO 10303-1:1994
ISO 22739:2024
Blockchain and distributed ledger technologies - Vocabulary
HISTORICAL EDITIONS: ISO 22739:2020
ISO 14960-2:2024
Tubeless tyres - Valves and components - Part 2: Clamp-in tubeless tyre valve - Test methods
HISTORICAL EDITIONS: ISO 14960-2:2014
ISO 6953-1:2024
Pneumatic fluid power - Compressed air pressure regulators and filter-regulators - Part 1: Main characteristics to include in suppliers literature and product-marking requirements
HISTORICAL EDITIONS: ISO 6953-1:2015, ISO 6953-1:2000
ISO 9613-2:2024
Acoustics - Attenuation of sound during propagation outdoors - Part 2: Engineering method for the prediction of sound pressure levels outdoors
HISTORICAL EDITIONS: ISO 9613-2:1996
ISO 8057:2024
Determination of galvanic corrosion rate for assembled forms of carbon fibre reinforced plastics (CFRPs) and protection-coated metal - Electrochemical tests in neutral sodium chloride solution
ISO 14960-2:2024
ISO 4685:2024
Water quality - Radium 226 - Test method using ICP-MS
ISO 14520-5:2024
ISO 6953-2:2024
Pneumatic fluid power - Compressed air pressure regulators and filter-regulators - Part 2: Test methods to determine the main characteristics to include in supplier’s literature
HISTORICAL EDITIONS: ISO 6953-2:2015, ISO 6953-2:2000
ISO 5688:2024
Textiles - Synthetic filament yarns - Test methods for crimp properties of textured yarns
ISO 20346:2021/Amd1:2024
- Amendment 1: Personal protective equipment - Protective footwear - Amendment 1
ISO 3262-10:2024
ISO 24510:2024
Activities relating to drinking water and wastewater services - Guidelines for the assessment and for the improvement of the service to users
HISTORICAL EDITIONS: ISO 24510:2007
ISO 5305:2024
Noise measurements for UAS (unmanned aircraft systems)
ISO 11816-2:2024
ISO 21438-2:2024
Workplace atmospheres - Determination of inorganic acids by ion chromatography - Part 2: Volatile acids, except hydrofluoric acid (hydrochloric acid, hydrobromic acid and nitric acid)
HISTORICAL EDITIONS: ISO 21438-2:2009
ISO 24613-1:2024
Language resource management - Lexical markup framework (LMF) - Part 1: Core model
HISTORICAL EDITIONS: ISO 24613-1:2019, ISO 24613:2008
ISO 12921:2024
Petroleum products and lubricants - Determination of the mechanical stability of greases in presence of water
ISO 5489:2024
Ships and marine technology - Embarkation ladders
HISTORICAL EDITIONS: ISO 5489:2008, ISO 5489:1986
ISO 20347:2021/Amd1:2024
- Amendment 1: Personal protective equipment - Occupational footwear - Amendment 1
ISO 20304-2:2024
Fine bubble technology - Water treatment applications - Part 2: Test methods using Escherichia coli as a test micro-organism
ISO 6017:2024
ISO 8728:2024
Ships and marine technology - Marine gyro-compasses
HISTORICAL EDITIONS: ISO 8728:2014, ISO 8728:1997
ISO 33401:2024
Reference materials - Contents of certificates, labels and accompanying documentation
HISTORICAL EDITIONS: ISO Guide 31:2015, ISO Guide 31:2000
ISO 11816-1:2024
ISO 7240-29:2024
ISO 4273:2024
Intelligent transport systems - Automated braking during low-speed manoeuvring (ABLS) - Requirements and test procedures
ISO 24489:2024
Non-destructive testing - Acoustic emission testing - Detection of corrosion at atmospheric and low-pressure metallic storage tank floors
ISO 22514-7:2021/Amd1:2024
- Amendment 1: Statistical methods in process management - Capability and performance - Part 7: Capability of measurement processes - Amendment 1
ISO 22739:2024
ISO 3262-11:2024
ISO 7431-2:2024
Thiourea for industrial use - Part 2: Specifications
ISO 16192:2024
Space systems - Lessons learned - Principles and guidelines
HISTORICAL EDITIONS: ISO 16192:2017, ISO 16192:2010
ISO 24322:2024
Timber structures - Methods of test for evaluation of long-term performance - Part 1: Wood-based products in bending
ISO 9557:2024
Ships and marine technology - Wire rope lifting platform for inspection
ISO 24591-1:2024
Smart water management - Part 1: General guidelines and governance
ISO 3882:2024
ISO 13315-1:2024
Environmental management for concrete and concrete structures - Part 1: General principles
HISTORICAL EDITIONS: ISO 13315-1:2012
ISO 6324:2024
Thermal insulation products - Flexible microporous insulation for industrial applications - Specification
ISO 9455-17:2024
ISO 20344:2021/Amd1:2024
- Amendment 1: Personal protective equipment - Test methods for footwear - Amendment 1
ISO 14373:2024
Resistance welding - Procedure for spot welding of uncoated and coated low-carbon steels
HISTORICAL EDITIONS: ISO 14373:2015, ISO 14373:2006
ISO 22007-4:2024
Plastics - Determination of thermal conductivity and thermal diffusivity - Part 4: Light flash method
HISTORICAL EDITIONS: ISO 22007-4:2017, ISO 22007-4:2008
ISO 24163-2:2024
Clamp-in tyre valves for tyre pressure monitoring systems - Part 2: Test methods and performance
ISO 22036:2024
Environmental solid matrices - Determination of elements using inductively coupled plasma optical emission spectrometry (ICP-OES)
HISTORICAL EDITIONS: ISO 22036:2008
ISO 11139:2018/Amd1:2024
- Amendment 1: Sterilization of health care products - Vocabulary of terms used in sterilization and related equipment and process standards - Amendment 1: Amended and additional terms and definitions
ISO 20345:2021/Amd1:2024
- Amendment 1: Personal protective equipment - Safety footwear - Amendment 1
ISO 8025:2024
ISO 19152-1:2024
原文地址:https://zhuanlan.zhihu.com/p/704009919
