查看: 10009|回复: 5
[分享] 为什么萤火虫可以发光?
发表于 2025-1-15 15:52 | 显示全部楼层 |阅读模式
为什么萤火虫可以发光?
原文地址:https://www.zhihu.com/question/371250411
Fireflies are fascinating insects that are known for their ability to produce light. This light is often referred to as "bioluminescence," which means they create their own light through a chemical reaction in their bodies.
萤火虫是迷人的昆虫,以其产生光亮的能力而闻名。这种光通常被称为“生物发光”,意味着它们通过体内的化学反应来产生自己的光。
Inside a firefly's abdomen, there are special cells called "photocytes" that contain a substance called "luciferin." When oxygen and an enzyme called "luciferase" come into contact with luciferin, a chemical reaction occurs, and it produces light.
在萤火虫的腹部内,有一种特殊的细胞叫做“光细胞”,其中含有一种叫做“荧光素”的物质。当氧气和一种叫做“荧光素酶”的酶与荧光素接触时,会发生化学反应,产生光亮。
This bioluminescent light that fireflies produce has different purposes. One main reason is for attracting mates. Male fireflies often fly around and emit flashes of light to communicate with females. Each firefly species has a unique pattern of flashes, like a secret code for finding a suitable partner.
萤火虫产生的这种生物发光光亮有不同的目的。主要的原因之一是吸引配偶。雄性萤火虫经常飞来飞去,发出闪烁的光亮与雌性交流。每个萤火虫物种都有独特的闪烁模式,就像寻找合适伴侣的秘密代码。
Another reason for their glowing is to warn predators that they taste bad. The light serves as a signal to predators that the fireflies are not a tasty meal, helping to keep them safe from being eaten.
它们发光的另一个原因是为了警告捕食者它们的味道不好。光亮作为一种信号告诉捕食者,萤火虫不是美味的食物,有助于保护它们免受捕食。
So, the ability of fireflies to glow is a fascinating adaptation that helps them communicate, find mates, and protect themselves in the natural world.
因此,萤火虫发光的能力是一种迷人的适应性,它能帮助它们在自然界中进行交流、寻找伴侣,并保护自己。
发表于 2025-1-15 15:53 | 显示全部楼层
萤火虫,不仅仅指的是一种昆虫,它是鞘翅目(甲虫)萤科中能够发光的昆虫的统称,全世界约2000种,主要分布于热带、亚热带和温带地区。
萤火虫有专门的发光细胞,其中的主要物质是萤火虫荧光素荧光素酶。简单来说,荧光素酶能有效的催化由萤火虫荧光素、氧气、三磷酸腺苷(ATP)、Mg2+组成的反应,同时将生物能转化成光能发出黄绿色荧光。
萤火虫的荧光会有一明一暗的变化,是因为呼吸时体内氧气浓度的变化影响了发光反应的进行。氧气浓度高时,发出的光就会亮一些,氧气浓度低时,光亮就会相对暗一些。
萤火虫的发光现象,是生物发光中的一种,也称作“冷光源”。因为这种反应非常高效,反应中释放的能量几乎全部以光的形式释放(反应效率为95%),几乎不产生什么热量,所以萤火虫也不会被自己发的光烫伤。
大自然的力量确实是让人敬佩的,虽然我们可以制造出更亮的光源,但却没办法制造出像生物发光一样高效的光源。我们使用的白炽灯只有约10%的能量被转化为光,其他能量都会变为热能被浪费掉。
大众科学,最具颠覆性的科技新知,满足你的猎奇心和求知欲。
雌性萤火虫是拥有「漂亮臀部」的生物,他们的雄性情人也是如此。在温暖的夏夜,它们在彼此发出的闪闪荧光中找到浪漫......
那么萤火虫的尾巴是怎样发光的呢?这其实是一个化学问题——被合适的季节、时令,或者被其他萤火虫的发光型号所触发。对于北美最常见的东方萤火虫,引起发光的信号是一场精心编排的舞蹈。下次,当你坐待路边或者草地上时,可以按照下面的指南。欣赏这些发光小生物的约会游戏。
身体部位按照A~B排序
发光原理
①初夏的前两个星期是萤火虫交配的季节。夜幕降临时,雌性萤火虫栖息在灌木丛和草地上,等待闪闪发光的雄性前来。
②雄性飞行时,氧气通过腹部的气管(A)进入腹腔。这些气管从昆虫的外骨骼表面通到发光的细胞。
③在发光细胞内部,荧光素酶与氧气和储能ATP催化所得的发光荧光素分子(B)结合,产生氧化荧光素——这是一种含有过剩能量的化合物。过剩的能量以光的形式,透过萤火虫下腹部的透明节释放出来。
④雄性萤火虫的腹部每5.5秒就闪光一次。当雌性看到心仪的雄性时,会在雄性发光约2秒后,用闪亮的信号应答雄性,暗送秋波。
⑤雄性追随雌性的光信号,找到它并且交配。几天后,雌性在土壤中产下受精卵,2~4周后完成孵化。
知识拓展——其他会发光的生物
——来大众科学,了解你不知道的科技与科学
发表于 2025-1-15 15:54 | 显示全部楼层
火虫发光原理
如果有仔细观察的人可能会发现,萤火虫的光有的是黄绿色,有的是橙色,有的亮,有的暗。发光的部位在腹部后两节,而且只有晚上才会发光。其实是因为萤火虫体内有发光细胞和一些能反射光的细胞,发光细胞含有两种特别的成份: 一种叫做荧光素,一种叫做荧光酶,这两种化学物质在有氧条件下将化学能转化为光能。萤火虫的光亮呈现出一闪一闪的样子,是因为萤火虫可以控制提供多少氧气给发光细胞,氧气多时便亮些
萤火虫发光目的
对于萤火虫发光的目的,根据早期学者提出的假设有求偶、沟通、照明、警示、展示及调节族群等功能,但是除了求偶、沟通这两个目的,其他功能也仅仅是科学家观察后得出的结果,甚至只是单纯的猜想。一直到最一九九几年才有研究证实了警示这个功能的真实存在,例如在1997年,有学者用幼年萤火虫对老鼠做实验发现,幼年萤火虫发光会对老鼠有警示作用。
发表于 2025-1-15 15:55 | 显示全部楼层
因为萤火虫的生理结构十分特殊,它腹部的末端内充满了许多含磷的发光质及发光酵素,简单来说,就是类似演唱会用的荧光棒中的发光材料。 因此这些含磷的发光质及发光酵素,会在萤火虫腹的部发出一闪一闪的微弱亮光,让萤火虫看起来像一只小灯泡。
不过萤火虫发出的亮光,不只是为了照明,其实主要是为了发送信号,而且每种用途发出的信号都是不同的。不同品种的萤火虫发光的频率、亮度、方式和颜色也都不同,就像人类使用的莫斯代码一样。
萤火虫在求偶、警戒、诱捕以及和同类之间的沟通时,都是通过这种方式进行交流的。
