查看: 9415|回复: 2
[分享] 为什么长余辉发光材料大多数是绿光?
发表于 2024-9-20 20:20 | 显示全部楼层 |阅读模式
为什么长余辉发光材料大多数是绿光?
原文地址:https://www.zhihu.com/question/54318018
发表于 2024-9-20 20:21 | 显示全部楼层
第一,通常来说,长余辉发光材料的发光强度相对于光致发光弱很多。在日光或者灯光下基本看不到,而黑暗环境下,蓝光和绿光更容易被观察到。
       第二,长余辉发光材料的历史发展原因。从古文献记载的夜明珠,再到1866年,出现的第一代长余辉ZnS:Cu,以及1996年Matsuzawa报道的划时代的长余辉材料SrAl2O4:Eu2+,Dy3+。这些长余辉材料都是绿光长余辉材料,而且这两种长余辉材料都被商业化推广,因此,日常中观察到的主要是绿光余辉。
       第三,其他颜色的长余辉材料应用前景不明朗,因此市面上几乎看不到。
       目前,长余辉发光材料的发光范围已经覆盖了从紫外到短波红外范围,尤其是近红外和短波红外长余辉在生物成像领域和夜视监测领域显示很大的潜力。现在所在的实验室在近几年开发了一系列优异的近红外和短波红外长余辉发光材料,余辉时间可达上百个小时。
       以下是近年发表的文章,有兴趣可以看一下。
Pan, Z., Lu, Y.Y. and Liu, F., 2012. Sunlight-activated long-persistent luminescence in the near-infrared from Cr3+-doped zinc gallogermanates. Nature materials, 11(1), pp.58-63. Sunlight-activated long-persistent luminescence in the near-infrared from Cr<sup>3+</sup>-doped zinc gallogermanates
Liu, F., Yan, W., Chuang, Y.J., Zhen, Z., Xie, J. and Pan, Z., 2013. Photostimulated near-infrared persistent luminescence as a new optical read-out from Cr3+-doped LiGa5O8. Scientific reports, 3. Photostimulated near-infrared persistent luminescence as a new optical read-out from Cr<sup>3+</sup>-doped LiGa<sub>5</sub>O<sub>8</sub>
Liu, F., Liang, Y. and Pan, Z., 2014. Detection of up-converted persistent luminescence in the near infrared emitted by the Zn3Ga2GeO8: Cr3+,Yb3+,Er3+ phosphor. Physical review letters, 113(17), p.177401. Detection of Up-converted Persistent Luminescence in the Near Infrared Emitted by the ${\mathrm{Zn}}_{3}{\mathrm{Ga}}_{2}{\mathrm{GeO}}_{8}:{\mathrm{Cr}}^{3+}$, ${\mathrm{Yb}}^{3+}$, ${\mathrm{Er}}^{3+}$ Phosphor
Liu, F., Liang, Y., Chen, Y. and Pan, Z., 2016. Divalent Nickel‐Activated Gallate‐Based Persistent Phosphors in the Short‐Wave Infrared. Advanced Optical Materials, 4(4), pp.562-566. Divalent Nickel‐Activated Gallate‐Based Persistent Phosphors in the Short‐Wave Infrared
Liang, Y.J., Liu, F., Chen, Y.F., Wang, X.J., Sun, K.N. and Pan, Z.W., 2016. New function of the Yb3+ ion as an efficient emitter of persistent luminescence in the short-wave infrared. Light Sci. Appl., 5(7), p.e16124. New function of the Yb<sup>3+</sup> ion as an efficient emitter of persistent luminescence in the short-wave infrared
Liang, Y., Liu, F., Chen, Y., Wang, X., Sun, K.N. and Pan, Z., 2017. Extending the applications for lanthanide ions: efficient emitters in short-wave infrared persistent luminescence. Journal of Materials Chemistry C. Extending the applications for lanthanide ions: efficient emitters in short-wave infrared persistent luminescence
Liang, Y., Liu, F., Chen, Y., Wang, X., Sun, K. and Pan, Z., 2017. Red/near-infrared/short-wave infrared multi-band persistent luminescence in Pr 3+-doped persistent phosphors. Dalton Transactions, 46(34), pp.11149-11153. Red/near-infrared/short-wave infrared multi-band persistent luminescence in Pr3+-doped persistent phosphors
本科是做荧光粉的,对发光材料有一定浅显了解。
首先长余辉发光材料在太阳能转换和利用方面具有独特的优势,白天可以将太阳能储存起来,晚上慢慢释放,是一类重要的光-光转换材料和节能材料,在中国俗称夜光粉或长余辉粉,学术上称为长磷光荧光体或长时发光材料。
我们很容易联想到夜明珠。夜明珠与一般长余辉发光材料发光机理相同, 由基质内含某些重金属杂质(激活剂)所引起,常有黄绿、浅蓝、橙红等颜色 ,印象中一般蓝绿色较多。
其次,长余辉发光材料的不同基质系列和不同的激活剂,组合起来会有不同的发光光谱特性,也会导致其发光颜色、发光强度、余辉时间不同。发光颜色是一般由基质发光颜色和激活剂发光颜色所共同决定。基质和激活剂共同发光的话会产生颜色叠加,单独激活剂发光产生绿光是由于激活剂的发射波段位于 500nm~560nm 之间(蓝光绿490~500nm、黄光绿 560~580nm )。
目前对于长余辉发光材料的研究大部分都集中在蓝绿色发光材料方面。其主要由绿光、蓝光、红光、白光等几类长余辉发光材料。
从目前的应用现状来看,绿色和蓝色的长余辉发光材料已经得到大量的推广和应用,特别是在安全消防、应急照明指示、夜光塑料及夜光涂料等日常消费领域中。
以上就是为何长余辉发光材料大多数是绿光的概述,具体机理不再深入,欢迎知友补充。
