查看: 40784|回复: 0
[分享] The Covid-19 antibody test challengeCOVID-19试剂盒开发面临的调整
发表于 2021-6-17 14:18 | 显示全部楼层 |阅读模式
In the current situation of the Covid-19 pandemic, reliable IgG antibody tests are urgently needed all around the world. Virologists caution against cross-reactivities that could potentially lead to false positives [1,2]. Using ELISAs as an example, we discuss the technical requirements for the development of truly dependable immunological testing methods, since the cross-reactivities debated by many virologists constitute only a small fraction of the actual challenges.
Known causes for “cross-reactivities” and false-positives
Four different causes for false-positives in serological assays are known:
1.Inappropriate capture antigens
2.Cross -reactivities and biochemical interferences
3.Insufficient surface blocking in serological assays
4.Stability of the reagents
如何解决此类问题,完整资料阅读:The Covid-19 antibody test challengeCOVID-1
