查看: 9034|回复: 0
[分享] SignalP+TMHMM预测微生物分泌蛋白
发表于 2025-1-22 16:44 | 显示全部楼层 |阅读模式
Secretory Protein是指在细胞内合成后,分泌到细胞外起作用的蛋白质。分泌蛋白的N 端有一般由15~30 个氨基酸组成的信号肽。信号肽是引导新合成的蛋白质向分泌通路转移的短(长度5-30个氨基酸)肽链。常指新合成多肽链中用于指导蛋白质的跨膜转移(定位)的N-末端的氨基酸序列(有时不一定在N端)。使用SignalP 注释蛋白序列是否含有信号肽结构,使用TMHMM注释蛋白序列是否含有跨膜结构,最终筛选出含有信号肽结构并且不含跨膜结构的蛋白为分泌蛋白
软件Software
  • SignalP V6.0
  • SignalP 6.0 预测来自古细菌、革兰氏阳性细菌、革兰氏阴性细菌和真核生物的蛋白质中存在的信号肽predicts signal peptides and the location of their cleavage sites in proteins from Archaea, Gram-positive Bacteria,及其切割位点的位置。Gram-negative Bacteria and Eukarya.在细菌和古细菌中,SignalP 6.0 可以区分五种类型的信号肽:In Bacteria and Archaea, SignalP 6.0 can discriminate between five types of signal peptides:
    • Sec/SPI:由 Sec 转座转运,并由信号肽酶 I (Lep) 切割的“标准”分泌信号肽;"Standard" secretory signal peptides transported by Sec translocon and cleaved by Signal Peptidase I (Lep).
    • Sec/SPII:由 Sec 转座子运输,并由信号肽酶 II (Lsp) 切割的脂蛋白信号肽;lipoprotein signal peptides transported by the Sec translocon and cleaved by Signal Peptidase II (Lsp).
    • Tat/SPI:由 Tat 转座子转运,并由信号肽酶 I (Lep) 切割的 Tat 信号肽;Tat signal peptides transported by the Tat translocon and cleaved by Signal Peptidase I (Lep).
    • Tat/SPII:由 Tat 转位子转运,并由信号肽酶 II (Lsp) 切割的 Tat 脂蛋白信号肽;Tat lipoprotein signal peptides transported by Tat translocon & cleaved by Signal Peptidase II (Lsp).
    • Sec/SPIII:由 Sec 转位子运输,并由信号肽酶 III (PilD/PibD) 切割的菌毛蛋白和菌毛蛋白样信号肽。Pilin & pilin-like signal peptides transported by Sec translocon & cleaved by Signal Peptidase III (PilD/PibD).
    • 此外,SignalP 6.0 预测信号肽的区域。Additionally, SignalP 6.0 predicts the regions of signal peptides.根据类型,预测 n、h 和 c 区域以及其他显着特征的位置。Depending on the type, the positions of n-, h- and c-regions as well as of other distinctive features are predicted.
  • TMHMM V2.0c
    • 用于预测蛋白质中的跨膜螺旋。
  • Python
SignalP和TMHMM对于学术用户免费,但是需要填写相关信息和邮箱,以接收下载链接(4h有效时间)。
软件安装Installation of Softwares
安装SignalP 6.0
  • 下载
    访问SignalP V6.0网站,找到“Download”,填写相关信息,获取下载链接,下载得到“signalp-6.0.fast.tar.gz”。有两个模式可以选择——“slow_sequential”和“fast"。前者runs the full model sequentially, taking the same amount of RAM as fast but being 6 times slower;后者uses a smaller model that approximates the performance of the full model, requiring a fraction of the resources and being significantly faste。本教程下载的是fast模式。
  • 安装Installation
    • 安装依赖Dependencies
      • Python
      • matplotlib>3.3.2
      • numpy>1.19.2
      • torch>1.7.0
        pip install torch
      • tqdm>4.46.1
    • 安装SignalP 6.0
      # 解压缩安装文件 tar zxvf signalp-6.0.fast.tar.gz  # 进入解压后的软件目录,在终端运行 python setup.py install  # 测试安装 signalp6 --help
安装TMHMM V2.0c
  • 下载
    访问TMHMM V2.0c网站,找到“Download”,填写相关信息,获取下载链接,下载得到“tmhmm-2.0c.Linux.tar.gz”。
  • 安装
    # 解压缩 tar zxvf tmhmm-2.0c.Linux.tar.gz  # 进入解压后的目录 cd tmhmm-2.0c  # 获取当前路径,我的是“/home/liu/tools/tmhmm-2.0c/bin” pwd # 将该路径加入到系统的环境变量中,参考我之前的文章来(编辑~/.bashrc)https://liaochenlanruo.github.io/post/f6c9.html#%E6%B7%BB%E5%8A%A0%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F # 修改bin目录下的tmhmm和tmhmmformat.pl的首行为“#!/usr/bin/perl”
  • 运行错误
    运行软件时总报Segmentation fault (core dumped)错误,暂时无解。各位可以使用其在线版
软件用法Usage
SignalP 6.0
预测Prediction
A command takes the following form
signalp6 --fastafile /path/to/input.fasta --organism other --output_dir path/to/be/saved --format txt --mode fast
  • fastafile 输入文件为FASTA格式的蛋白序列文件Specifies the fasta file with the sequences to be predicted.。
  • organism is either other or Eukarya. Specifying Eukarya triggers post-processing of the SP predictions to prevent spurious results (only predicts type Sec/SPI).
  • format can take the values txt, png, eps, all. It defines what output files are created for individual sequences. txtproduces a tabular .gff file with the per-position predictions for each sequence. png, eps, all additionally produce probability plots in the requested format. For larger prediction jobs, plotting will slow down the processing speed significantly.
  • mode is either fast, slow or slow-sequential. Default is fast, which uses a smaller model that approximates the performance of the full model, requiring a fraction of the resources and being significantly faster. slow runs the full model in parallel, which requires more than 14GB of RAM to be available. slow-sequential runs the full model sequentially, taking the same amount of RAM as fast but being 6 times slower. If the specified model is not installed, SignalP will abort with an error.
输出Outputs
  • output_dir/output.gff3:仅包含含有信号肽的序列信息;
  • output_dir/prediction_results.txt:包含了输入文件中的所有序列(不重要);
  • output_dir/region_output.gff3:包含所有的信号肽区域信息。
    • n-region: The n-terminal region of the signal peptide. Reported for Sec/SPI, Sec/SPII, Tat/SPI and Tat/SPII. Labeled as N
    • h-region: The center hydrophobic region of the signal peptide. Reported for Sec/SPI, Sec/SPII, Tat/SPI and Tat/SPII. Labeled as H
    • c-region: The c-terminal region of the signal peptide, reported for Sec/SPI and Tat/SPI.
    • Cysteine: The conserved cysteine in +1 of the cleavage site of Lipoproteins that is used for Lipidation. Labeled as c.
    • Twin-arginine motif: The twin-arginine motif at the end of the n-region that is characteristic for Tat signal peptides. Labeled as R.
    • Sec/SPIII: These signal peptides have no known region structure.
批处理与结果优化
脚本名:run_SignalP.pl
#!/usr/bin/perl
use strict;
use warnings;
# Author: Liu Hualin
# Date: Oct 14, 2021
open IDNOSEQ, ">IDNOSEQ.txt" || die;
my @faa = glob("*.faa");
foreach  (@faa) {
        $_ =~ /(.+).faa/;
        my $str = $1;
        my $out = $1 . ".nodesc";
        my $sigseq = $1 . ".sigseq";
        my $outdir = $1 . "_signalp";
        open IN, $_ || die;
        open OUT, ">$out" || die;
        while (<IN>) {
                chomp;
                if (/^(>\S+)/) {
                        print OUT $1 . &#34;\n&#34;;
                }else {
                        print OUT $_ . &#34;\n&#34;;
        close IN;
        close OUT;
        my %hash = idseq($out);
        system(&#34;signalp6 --fastafile $out --organism other --output_dir $outdir --format txt --mode fast&#34;);
        my $gff = $outdir . &#34;/output.gff3&#34;;
        if (! -z $gff) {
                open IN, &#34;$gff&#34; || die;
                <IN>;
                open OUT, &#34;>$sigseq&#34; || die;
                while (<IN>) {
                        chomp;
                        my @lines = split /\t/;
                        if (exists $hash{$lines[0]}) {
                                print OUT &#34;>$lines[0]\n$hash{$lines[0]}\n&#34;;
                        }else {
                                print IDNOSEQ $str . &#34;\t&#34; . &#34;$lines[0]\n&#34;;
                close IN;
                close OUT;
        system(&#34;rm $out&#34;);
        system(&#34;mv $sigseq $outdir&#34;);
close IDNOSEQ;
sub idseq {
        my ($fasta) = @_;
        my %hash;
        local $/ = &#34;>&#34;;
        open IN, $fasta || die;
        <IN>;
        while (<IN>) {
                chomp;
                my ($header, $seq) = split (/\n/, $_, 2);
                $header =~ /(\S+)/;
                my $id = $1;
                $hash{$id} = $seq;
        close IN;
        return (%hash);
将run_SignalP.pl与后缀名为“.faa”的FASTA格式文件放在同一目录下,在终端中运行如下代码:
perl run_SignalP.pl
结果解读Output interpretation
*代表输入文件的名字。
  • *_signalp/output.gff3:仅包含含有信号肽的序列信息;
  • *_signalp/prediction_results.txt:包含了输入文件中的所有序列(不重要);
  • *_signalp/region_output.gff3:包含所有的信号肽区域信息;
  • *_signalp/*.sigseq:存储所有信号肽的氨基酸序列文件,可用作TMHMM的输入文件。
TMHMM
预测
离线版总是报错,找不出原因,因此使用网页服务器进行,输入文件为上述生成的“*_signalp/*.sigseq”,将其上传至网页版TMHMM,提交任务,等待结果即可。
结果展示
TMHMM可以输出多种格式的结果文件,具体请参考其官方说明
在TMHMM网站提交任务
  • Long output format
    • Length: 蛋白序列的长度。The length of the protein sequence.
    • Number of predicted TMHs:预测到的跨膜螺旋的数量。The number of predicted transmembrane helices.
    • Exp number of AAs in TMHs:跨膜螺旋中氨基酸的预期数量。The expected number of amino acids intransmembrane helices. 如果此数字大于 18,则很可能是跨膜蛋白(或具有信号肽)。If this number is larger than 18 it is very likely to be a transmembrane protein (OR have a signal peptide).
    • Exp number, first 60 AAs:在蛋白的前60个氨基酸中跨膜螺旋中氨基酸的预期数量。The expected number of amino acids in transmembrane helices in the first 60 amino acids of the protein.如果该数字超过几个,你应该被警告在 N 端预测的跨膜螺旋可能是一个信号肽。If it more than a few, you are warned that a predicted transmembrane helix in the N-term could be a signal peptide.
    • Total prob of N-in:N端在膜的细胞质一侧的总概率。The total probability that the N-term is on the cytoplasmic side of the membrane.
    • POSSIBLE N-term signal sequence:当“Exp number, first 60 AAs”大于 10 时产生的警告。A warning that is produced when &#34;Exp number, first 60 AAs&#34; is larger than 10.
  • 蛋白F01_bin.1_00110共计436个氨基酸,有5个跨膜螺旋结构。
  • 蛋白F01_bin.1_00142共计557个氨基酸,所有序列均在膜外,即该序列编码的是分泌蛋白。
  • Short output format
    • &#34;len=&#34;: 蛋白序列的长度。The length of the protein sequence.
    • &#34;ExpAA=&#34;:跨膜螺旋中氨基酸的预期数量。The expected number of amino acids intransmembrane helices.如果此数字大于 18,则很可能是跨膜蛋白(或具有信号肽)。If this number is larger than 18 it is very likely to be a transmembrane protein (OR have a signal peptide).
    • &#34;First60=&#34;:在蛋白的前60个氨基酸中跨膜螺旋中氨基酸的预期数量。The expected number of amino acids in transmembrane helices in the first 60 amino acids of the protein.如果该数字超过几个,你应该被警告在 N 端预测的跨膜螺旋可能是一个信号肽。If it more than a few, you are warned that a predicted transmembrane helix in the N-term could be a signal peptide.
    • &#34;PredHel=&#34;:预测到的跨膜螺旋的数量。The number of predicted transmembrane helices by N-best.
    • &#34;Topology=&#34;:N-best 预测的拓扑结构。The topology predicted by N-best.拓扑是由跨膜螺旋的位置给出的,如果螺旋在内部,则由“i”分隔,如果螺旋在外部,则由“o”分隔。&#39;i7-29o44-66i87-109o&#39;意味着它从膜内开始,在位置7到29有一个预测的TMH,30-43在膜外,然后是位置44-66的TMH。
结果汇总
通过网页版预测我们仅得到了一个列表文件(Short output format),该文件需要自己复制网页内容粘贴到新文件中,我将其命名为*_TMHMM_SHORT.txt,并将其存放在*_signalp目录中,该目录是由run_SignalP.pl生成的。下面我将会统计各个基因组中信号肽蛋白的总数量、分泌蛋白数量和跨膜蛋白数量到文件Statistics.txt中,并分别提取每个基因组的分泌蛋白序列到*_signalp/*.secretory.faa文件中,提取跨膜蛋白序列到*_signalp/*.membrane.faa文件中。该过程将通过tmhmm_parser.pl完成。
#!/usr/bin/perl use strict; use warnings; # Author: Liu Hualin # Date: Oct 15, 2021 open OUT, &#34;>Statistics.txt&#34; || die; print OUT &#34;Strain name\tSignal peptide numbers\tSecretory protein numbers\tMembrane protein numbers\n&#34;; my @sig = glob(&#34;*_signalp&#34;); foreach my $sig (@sig) {         $sig=~/(.+)_signalp/;         my $str = $1;         my $tmhmm = $sig . &#34;/$str&#34; . &#34;_TMHMM_SHORT.txt&#34;;         my $fasta = $sig . &#34;/$str&#34; . &#34;.sigseq&#34;;         my $secretory = $str . &#34;.secretory.faa&#34;;         my $membrane = $str . &#34;.membrane.faa&#34;;         open SEC, &#34;>$secretory&#34; || die;         open MEM, &#34;>$membrane&#34; || die;         my $out = 0;         my $on = 0;         my %hash = idseq($fasta);         open IN, $tmhmm || die;         while (<IN>) {                 chomp;                 $_=~s/[\r\n]+//g; #                print $_ . &#34;\n&#34;; my @lines = split /\t/;                 if ($lines[5] eq &#34;Topology=o&#34;) {                         $out++;                         print SEC &#34;>$lines[0]\n$hash{$lines[0]}\n&#34;;                 }else {                         $on++;                         print MEM &#34;>$lines[0]\n$hash{$lines[0]}\n&#34;;                 }         }         close IN;         close SEC;         close MEM;         system(&#34;mv $secretory $membrane $sig&#34;);         my $total = $out + $on;         print OUT &#34;$str\t$total\t$out\t$on\n&#34;; }  close OUT;  sub idseq {         my ($fasta) = @_;         my %hash;         local $/ = &#34;>&#34;;         open IN, $fasta || die;         <IN>;         while (<IN>) {                 chomp;                 my ($header, $seq) = split (/\n/, $_, 2);                 $header =~ /(\S+)/;                 my $id = $1;                 $hash{$id} = $seq;         }         close IN;         return (%hash); }
运行方法:将tmhmm_parser.pl放在*_signalp的上一级目录下,*_signalp目录中必须包含*_TMHMM_SHORT.txt文件和*.sigseq文件。在终端运行如下代码:
perl tmhmm_parser.pl
脚本获取
本文脚本见GitHub
敬告:使用文中脚本请引用本文网址,请尊重本人的劳动成果,谢谢!Notice: When you use the scripts in this article, please cite the link of this webpage. Thank you!
参考
原文链接:SignalP+TMHMM预测微生物分泌蛋白 | liaochenlanruo
转载请注明出处!
http://weixin.qq.com/r/HUzl-XvE6CaXrT_e9xkP (二维码自动识别)
原文地址:https://zhuanlan.zhihu.com/p/423757806
