查看: 8873|回复: 0
[分享] 蛋白质理化性质和一,二级结构分析
发表于 2024-12-26 05:24 | 显示全部楼层 |阅读模式
蛋白质理化性质和一级结构分析
使用expasy protparam(http://web.expasy.org/protparam/)进行在线预测。
或者直接打开,搜索ProtParam。就能看到
粘贴你的蛋白序列
点击compute parameters
就能得到以下界面与数据:
Number of amino acids (氨基酸数量): XXXXX
Molecular weight 分子量: XXXXX
Theoretical pI 理论等电点: XXXXX
Amino acid composition:
Ala (A)  67         18.6%
Arg (R)  29          8.0%
Asn (N)   5          1.4%
Asp (D)  23          6.4%
Cys (C)   5          1.4%
Gln (Q)  21          5.8%
Glu (E)  13          3.6%
Gly (G)  24          6.6%
His (H)  12          3.3%
Ile (I)   3          0.8%
Leu (L)  24          6.6%
Lys (K)  13          3.6%
Met (M)   8          2.2%
Phe (F)   5          1.4%
Pro (P)  22          6.1%
Ser (S)  47         13.0%
Thr (T)  13          3.6%
Trp (W)   6          1.7%
Tyr (Y)   3          0.8%
Val (V)  18          5.0%
Pyl (O)   0          0.0%
Sec (U)   0          0.0%
(B)   0          0.0%
(Z)   0          0.0%
(X)   0          0.0%
Total number of negatively charged residues 带负电的残基总数 (Asp + Glu):xx
Total number of positively charged residues 带正电的残基总数 (Arg + Lys):xx
Atomic composition:
Carbon      C              XXXX
Hydrogen    H              XXXX
Nitrogen    N               5XXX
Oxygen      O               XX
Sulfur      S                1X
Formula: XXXXXX
Total number of atoms: XXXXX
Extinction coefficients 消光系数:
Extinction coefficients are in units of  M-1 cm-1, at 280 nm measured in water.
在水中测量的280 nm处的消光系数以M-1 cm-1为单位。
Ext. coefficient    XXXX
Abs 0.1% (=1 g/l)   XXXXXX, assuming all pairs of Cys residues form cystines假设所有对Cys残基都形成胱氨酸时消光系数
Abs 0.1% (=1 g/l)   XXXX, assuming all Cys residues are reduced假设所有Cys残基都减少时消光系数
Estimated half-life 半衰期:
The N-terminal of the sequence considered is M (Met).
The estimated half-life is: XXhours (mammalian reticulocytes, in vitro).
                            >XX hours (yeast, in vivo).
                            >1XX hours (Escherichia coli, in vivo).
Instability index 不稳定性指数:
The instability index (II) is computed to be 不稳定性指数(II)计算为 XXX
一般这个指数小于40,则说明稳定;大于40不稳定该蛋白质归类为不稳定蛋白质。
Aliphatic index 脂溶指数: XXXX
小于100比较亲水
Grand average of hydropathicity 亲水性平均值 (GRAVY): XXXX
定义为序列中所有氨基酸亲水值的总和与氨基酸数量的比值,负值越大表示亲水性越好好,正值越大表示疏水性越强。
蛋白质二级结构分析
TMHMM 法分析蛋白质的跨膜区:TMHMM 2.0 - DTU Health Tech - Bioinformatic Services
我这个就是个胞外蛋白。
SOPMA--蛋白二级结构预测
NPS@ : SOPMA secondary structure prediction (ibcp.fr)
粘贴序列,点击submit,就会跳到这个界面
等待加载后,就会出现一些这样的东西。
蓝色:α-螺旋(Alpha helix)
绿色: β-折叠(Beta turn )
黄色: 无规则卷曲(Random coil)
红色: 延伸链(Extended strand)
Pfam预测蛋白质功能
选择SEQUENCE SEARCH,粘贴你自己的蛋白质序列
点go,就会跳转到这个界面,
点search
经过漫长的等待后,就能看到结果啦。
原文地址:https://zhuanlan.zhihu.com/p/628188657
